Place Family Instance from .csv files points
   I want to place Family Instance which I select from active document on points which get from csv file. I use this code which is from following link but it showing the error.
http://thebuildingcoder.typepad.com/blog/2012/02/add-reference-points-from-csv-file.html
This is the code:-
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
UIApplication uiapp = commandData.Application;
UIDocument uidoc = uiapp.ActiveUIDocument;
Application app = uiapp.Application;
Document doc = uidoc.Document;
using (Transaction t = new Transaction(doc, "csv"))
t.Start();
string filepath = "E:\\Points.csv";
if (File.Exists(filepath))
StreamReader s = new StreamReader(
filepath);
TaskDialog.Show("Revit","Read csv File");
Reference pickrdRef = null;
//pick a group
Selection sel = uiapp.ActiveUIDocument.Selection;
pickrdRef = sel.PickObject(ObjectType.Element, "Please select a group");
TaskDialog.Show("Revit", "Select Your Marker");
while (-1 != s.Peek())
string line = s.ReadLine();
string[] data = line.Split(
new char[] { ',' });
XYZ p = app.Create.NewXYZ(
double.Parse(data[0]),
double.Parse(data[1]),
double.Parse(data[2]));
ReferencePoint rp = doc.FamilyCreate.NewReferencePoint(p);
else
TaskDialog.Show("Revit","Files Does not Exists");
t.Commit();
return Result.Succeeded;
Use NewFamilyInstance() for placing family instance on points.
jeremytammik
For a complete and tested example add-in implementing this, please refer to The Building Coder:
http://thebuildingcoder.typepad.com/blog/2013/10/text-file-driven-automatic-placement-of-family-inst...
Jeremy Tammik
Developer Technical Services
The Building Coder
I have downloaded the add-in, but we are unable to place the family automatically at the given coordinates.
I have given coordinates in text file in following format.
x
y
z
Can you please give solution for this.
If possible can you share one example text file.
Libna
jeremytammik
As far as I can tell from the code, it expects two or three real numbers per text line for XY or XYZ coordinates.
Try feeding it the data in the following format:
  X1 Y1 Z1
  X2 Y2 Z2
Why don't you just debug it and see what is going on?
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Now I am working in visual studio 2017 express, so that I am not able to debug external programs. I have raised request in my organisation for installing professional version in my system. Once installed I will debug the code.
Thanks for your replay.
