Place a door tag at the centre of the door opening leaf
Hi Yall,
 I am currently working on a problem. It seems simple enough but it is driving me up the wall.
Revit as it stands, places Door tags over the centre line of the door threshold (2d), and I have to manually modify the door tags to fit within the opening space of the door leaf (the curvy part) opposite the hosting wall.
does anyone know a simple way of finding the centre point of a door opening and then applying a door tag to that point or if there is already a door tag there, moving it to that location?
My Code as stand is the following.
using System;
using System.Collections.Generic;
using System.Linq;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
namespace DoorTags
    [TransactionAttribute(TransactionMode.Manual)]
    [RegenerationAttribute(RegenerationOption.Manual)]
    public class doorTags : IExternalCommand
        public Result Execute(
          ExternalCommandData commandData,
          ref string message,
          ElementSet elements)
            //Get application and document objects
            UIApplication uiApp = commandData.Application;
            Document doc = uiApp.ActiveUIDocument.Document;
            // Set cursor as hour glass
            Cursor.Current = Cursors.WaitCursor;
            Dim collector As Dictionary(Of String, List(Of DB.FamilyInstance)) = _
            New DB.FilteredElementCollector(doc).OfClass(GetType(DB.FamilyInstance)).OfCategory(DB.BuiltInCategory.OST_Doors).Cast(Of DB.FamilyInstance).GroupBy(Function(fi) fi.Symbol.Family.Name).ToDictionary(Of String, List(Of DB.FamilyInstance))
            (Function(f) f.Key, Function(f) f.ToList);
            // test if the family name string contains "single"
            Dim searchString as String = "Single";
            for Each key as String in collector.Keys
                if key.Contains(searchString, StringComparison.CurrentCultureIgnoreCase)
                    //Get door current location
                    LocationPoint DoorLocation = OST.Doors.Location as LocationPoint;
                    XYZ oldPlace = DoorLocation.Point;
                    //Get door swing direction
                    // calculate new door tag location
                    if (condition) // tag already exists
                        XYZ DoorTagPlace = new XYZ();
                        ElementTransformUtils.MoveElement(document, column.Id, newPlace); (condition)
                    else
                        then(condition)// no door tag exisiting
                    //find the direction of the door opening which will help us work out where to place the door tag
                    bool condition = true; // the door swings inward, place the door tag on the inside of the door relative to the centre of the hosting door.
                    if (condition)
                        // move door tag to the inside of the wall to the centre of the opening door leaf
                    else
                        // move the door tag to the outside of the wall to the centre of the opening door leaf
            // Set cursor as default arrow
            Cursor.Current = Cursors.Default;
I am also placing a timer for the operation, so the more efficient my method, the better. any help would be greatly appreciated.
BobbyC.Jones
I'm not sure I completely understand your requirements, but it sounds like you're trying to find the centroid of the triangle formed by the door opening and the door leaf.
Bobby C. Jones
Hi Bobby,
 Yes that is what I am after. From that I want to place a door tag at that position, if there is already a door tag there, then move the door tag to that position. Does that make more sense now?
Yes that is right. I want to find the central and then place the door tag
at that point.
BobbyC.Jones
@Anonymous wrote:
Hi Bobby,
I think the triangle centroid formula in my previous link is pretty straight forward to implement, and I see that in another post @Revitalizer has provided a  direction that could also prove to be fairly easy to implement.  As for determining if the door is already tagged, @jeremytammik has some info on The Building Coder blog.  Does that give you enough direction, or is there something more specific you're stuck on?
Bobby C. Jones
