pipe end point Elements
Dear Forum Members
I need to find out all pipes whose end points are not connected to anything. I can find out the pipes end point LocationCurve but I need to check that the pipes endpoint is connected to some element or not.
Thanks & Regards
jeremytammik
Dear Sanjaymann,
Just googling for it should give you more than enough information, e.g.
http://lmgtfy.com/?q=building+coder+mep+pipe+connected
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
That was so sweet of you to google that for me.
I try to make sure that if after reading the api and then googling on the topic I don't find a solution then I post it on the forum.
Let me rephrase:
In Revit 2014 there is a functionality to cap open ended pipes. Similiar to that I want to write a code to find open ended pipes but my target version is 2013.
I hope I was able to make understand the scenario.
Thanks & Regards
Dear members,
The following code solved it:
foreach (Pipe pp in new FilteredElementCollector(Command.doc).OfClass(typeof(Pipe)))
  foreach (Connector c in pp.ConnectorManager.Connectors)
     if (c.IsConnected == true)
       MessageBox.Show("Closed End");
   else
     MessageBox.Show("Open End");
