Pipe direction
Pipe direction
Pipe direction
How do I check that a pipe is upward or downward.
Thanks & Regards
Sanjay Pandey
jeremytammik
Dear Sanjay,
How about simply asking it for its curve and checking the start and end points?
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
I compared the Z of the pipe's start point and end point. If the Z of the pipe's end point is more then the Z of the pipe's start point the pipe if upward and vice versa.
Thanks & Regards
Sanjay Pandey
jeremytammik
Dear Sanjay,
Good. That is exactly what I meant. I love going to the underlying geometry for non-equivocal results. Glad it helped. Thank you for the confirmation.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
