PickObject to select room in current model or linked models?
juqing27
Message 1 of 12
juqing27
Hello Community,
This may be somehow old but I cannot find a good solution for my specific case here 🙂 I’m working on a Revit addin and would like to prompt user to select a room in model. The room can be from either the current model or the linked models. With the help from previous posts in the forum I’m able  to make some progress so far, but still none of the approaches is ideal. Here are what I’ve tried and the downside –
  1. PickObject(ObjectType.Element, roomSelectionFilter). This works great for rooms in current model, but won’t allow user to select rooms from linked models.
  2. PickObject(ObjectType.LinkedElement, roomSelectionFilter_linkedRoom). This is the opposite of 1.: works great for rooms in linked models, but won’t allow user to select rooms from current model.
  3. PickObject(ObjectType.PointOnElement). This one allows user to select elements in both current and linked models. However, it’s not limited to rooms  - or at least I haven’t come up with a proper ISelectionFilter to achieve so.
So, any ideas? I’m thinking if there’s a way to combine 1. and 2. in one pick, or maybe there can be a ISelectionFilter to filter out anything that is not a room for 3.? Appreciate your help!
Replies (11)
Message 2 of 12
jeremytammik
Please share the code for the two filters that you mention, roomSelectionFilter and roomSelectionFilter_linkedRoom.
Selection filters are very flexible, easy to understand and implement.
Therefore, the two can very probably be combined into one that performs a Boolean OR between the two types of filtering required.
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 12
juqing27
Thanks Jeremy! Edited my post to include the two filters I've tried. Thank you! -
  • PickObject(ObjectType.Element, new RoomSelectionFilter(_doc)). This works great for rooms in current model, but won’t allow user to select rooms from linked models. Code for the filter -
public class RoomSelectionFilter : ISelectionFilter
        Document doc = null;
        public RoomSelectionFilter(Document document)
            doc = document;
        public bool AllowElement(Element elem)
            if (elem.Category.Id.IntegerValue == (int)BuiltInCategory.OST_Rooms)
                return true;
            return false;
        public bool AllowReference(Reference reference, XYZ position)
            //return false;
            RevitLinkInstance revitlinkinstance = doc.GetElement(reference) as RevitLinkInstance;
            Autodesk.Revit.DB.Document docLink = revitlinkinstance.GetLinkDocument();
            Element eRoomLink = docLink.GetElement(reference.LinkedElementId);
            if (eRoomLink.Category.Id.IntegerValue == (int)BuiltInCategory.OST_Rooms)
                return true;
            return false;
  • PickObject(ObjectType.LinkedElement, new RoomSelectionFilter_linkedRoom(_doc)). This is the opposite of 1.: works great for rooms in linked models, but won’t allow user to select rooms from current model. Code for the filter -
public class RoomSelectionFilter_Linked : ISelectionFilter
        public RoomSelectionFilter_Linked(Document document)
            doc = document;
            return true;
            //return false;
                return true;
            return false;
  • PickObject(ObjectType.PointOnElement). This one allows user to select elements in both current and linked models. However, it’s not limited to rooms  - or at least I haven’t come up with a proper ISelectionFilter to achieve so.
Message 4 of 12
RPTHOMAS108
There is no perfect solution for this. Ideally there would be a separate flags argument for deciding where the items come from and then can do away with ObjectType.LinkedElement i.e.:
OutsideLink = 1
WithinLink = 2
Both = 1 + 2
You could try a looping strategy such as below where you click once for a link or room and then if link click again for a room in the link. I would not advise using pickpoint as you would require an active work plane and depending on the depth of this within the view you may not be picking on an element you believe you are picking. You can achieve the same as below in C# with while loop.
 Public Class CatSelFilter
        Implements Selection.ISelectionFilter
        Public Property Categories As List(Of Integer)
        Public Function AllowElement(elem As Element) As Boolean Implements Selection.ISelectionFilter.AllowElement
            If elem.Category Is Nothing Then Return False Else
            Return Categories.Contains(elem.Category.Id.IntegerValue)
        End Function
        Public Function AllowReference(reference As Reference, position As XYZ) As Boolean Implements Selection.ISelectionFilter.AllowReference
            Return True
        End Function
    End Class
    Public Function TObj81(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
ByRef message As String, ByVal elements As Autodesk.Revit.DB.ElementSet) As Result
        Dim doc As Document = commandData.Application.ActiveUIDocument.Document
        Dim uiDoc As UIDocument = commandData.Application.ActiveUIDocument
        Dim R As Reference = Nothing
        Dim SelType As Selection.ObjectType = Selection.ObjectType.Element
        Dim Cfilt As New CatSelFilter
        Cfilt.Categories = {CInt(BuiltInCategory.OST_Rooms), CInt(BuiltInCategory.OST_RvtLinks)}.ToList
back:
        Try
            R = uiDoc.Selection.PickObject(SelType, Cfilt)
        Catch ex As Exception
        End Try
        If R Is Nothing Then Return Result.Cancelled Else
        Dim RvtLnk As RevitLinkInstance = TryCast(doc.GetElement(R), RevitLinkInstance)
        If RvtLnk Is Nothing = False AndAlso SelType = Selection.ObjectType.Element Then
            SelType = Selection.ObjectType.LinkedElement
            GoTo back
        Dim El As Element = Nothing
        If SelType = Selection.ObjectType.LinkedElement Then
            El = RvtLnk.GetLinkDocument.GetElement(R.LinkedElementId)
        Else
            El = doc.GetElement(R)
        Return Result.Succeeded
    End Function
Message 5 of 12
juqing27
Thanks @RPTHOMAS108 ! Pick (a room or link) - decide whether a room or a link is selected - prompt another pick if a link is selected in the first one seems to be a good workaround at this time.
Still hoping @jeremytammik  could advise on how (or if it's possible) to build a ISelectionFilter that allows room room both current model and linked models. 🙂
Best,
Qing
Message 6 of 12
jeremytammik
Dear Richard,
Thank you for your good advice and solution. It looks nice and clean to me, very convincing.
I was hoping that something like ObjectType.PointOnElement could be used and the selection filter expanded to accept a point on either a room element or on a room element within a linked file.
I'm still not convinced that it cannot be done.
Have you tried that out?
Qing Ju, have you?
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 12
juqing27
@jeremytammik @RPTHOMAS108 I'd love to try the route @jeremytammik suggest (PickObject(ObjectType.PointOnElement) with a proper selection filter, the 3rd approach in my original post 🙂 but I'm pretty new to Revit API and don't seem to be able to make the filter work for rooms from both current model and linked model... Can you show me some general idea, or point me to any similar example?
Thank you both!
Qing
Message 8 of 12
RPTHOMAS108
@jeremytammik you are correct .PointOnElement does provide a better approach thanks for highlighting this to me.
@juqing27 I have included below an Implementation of ISelectionFilter using generics. I've included this in VB but should be easy to convert to C#.
 Public Class ElementInLinkSelectionFilter(Of T As Element)
        Private IntDoc As Document
        Private IntLastCheckedWasFromLink As Boolean = False
        Private IntLinkDoc As Document = Nothing
        Public Sub New(Doc As Document)
            IntDoc = Doc
        End Sub
        Public ReadOnly Property LinkDocument As Document
            Get
                Return IntLinkDoc
            End Get
        End Property
        Public ReadOnly Property LastCheckedWasFromLink As Boolean
            Get
                Return IntLastCheckedWasFromLink
            End Get
        End Property
            Return True
        End Function
            Dim El As Element = IntDoc.GetElement(reference)
            Dim RvtLnkInst As RevitLinkInstance = TryCast(El, RevitLinkInstance)
            If RvtLnkInst Is Nothing = False Then
                IntLastCheckedWasFromLink = True
                Dim LnkDoc As Document = RvtLnkInst.GetLinkDocument
                Dim ClsInst As T = TryCast(LnkDoc.GetElement(reference.LinkedElementId), T)
                If ClsInst Is Nothing = False Then
                    IntLinkDoc = RvtLnkInst.GetLinkDocument
                    Return True
            Else
                IntLastCheckedWasFromLink = False
                IntLinkDoc = Nothing
                Dim ClsInst As T = TryCast(El, T)
                    Return True
            Return False
        End Function
    End Class
ISelectionFilter implementation.
Public Function TObj82(ByVal commandData As Autodesk.Revit.UI.ExternalCommandData,
        Dim SelType As Selection.ObjectType = Selection.ObjectType.PointOnElement
        Dim Cfilt As New ElementInLinkSelectionFilter(Of Room)(doc)
        Try
        End Try
        If Cfilt.LastCheckedWasFromLink Then
            El = Cfilt.LinkDocument.GetElement(R.LinkedElementId)
        Else
        TaskDialog.Show("Picked", El.Name)
    End Function
Usage
Message 9 of 12
RPTHOMAS108
Above in C#
public class ElementInLinkSelectionFilter<T> : ISelectionFilter where T : Element
			private Document IntDoc;
			private bool IntLastCheckedWasFromLink = false;
			private Document IntLinkDoc = null;
			public ElementInLinkSelectionFilter(Document Doc)
				IntDoc = Doc;
			public Document LinkDocument
				get { return IntLinkDoc; }
			public bool LastCheckedWasFromLink
				get { return IntLastCheckedWasFromLink; }
				return true;
				Element El = IntDoc.GetElement(reference);
				RevitLinkInstance RvtLnkInst = El as RevitLinkInstance;
				if (RvtLnkInst == null == false)
					IntLastCheckedWasFromLink = true;
					Document LnkDoc = RvtLnkInst.GetLinkDocument();
					T ClsInst = LnkDoc.GetElement(reference.LinkedElementId) as T;
					if (ClsInst == null == false)
						IntLinkDoc = RvtLnkInst.GetLinkDocument();
						return true;
				else
					IntLinkDoc = null;
					T ClsInst = El as T;
						return true;
				return false;
public Result TObj82(Autodesk.Revit.UI.ExternalCommandData commandData, ref string message, Autodesk.Revit.DB.ElementSet elements)
			Document doc = commandData.Application.ActiveUIDocument.Document;
			UIDocument uiDoc = commandData.Application.ActiveUIDocument;
			Reference R = null;
			ObjectType SelType = ObjectType.PointOnElement;
			ElementInLinkSelectionFilter<Room> Cfilt = new ElementInLinkSelectionFilter<Room>(doc);
			try
				R = uiDoc.Selection.PickObject(SelType, Cfilt);
			catch (Exception)
			if (R == null)
				return Result.Cancelled;
			Element El = null;
			if (Cfilt.LastCheckedWasFromLink)
				El = Cfilt.LinkDocument.GetElement(R.LinkedElementId);
			else
				El = doc.GetElement(R);
			TaskDialog.Show("Picked", El.Name);
			return Result.Succeeded;
Usage
I've extracted the LinkedDocument and determined the nature of the reference within the ISelectionFilter. It may be preferable to determine again these things outside. I just don't like going through the same process twice but since the filter is called when you hover over an element and not when you select an element it may be wise to move getting the linked document and determining again if the reference is from a link outside of ISelectionFilter.
You can also simplify the null checking of the above converted by using '!=' etc.
Message 10 of 12
juqing27
This is great! Thanks for combining the solution decently into one click!
Message 11 of 12
jeremytammik
Very nice indeed!
Thank you for putting that together.
This is really worth saving, I think, so I cleaned it up and added it to The Building Coder samples.
Here is the diff to the previous version:
https://github.com/jeremytammik/the_building_coder_samples/compare/2021.0.149.2.../2021.0.150.0
Here is my version of your selection filter:
  private Document _doc;
  public ElementInLinkSelectionFilter( Document doc )
    _doc = doc;
  public Document LinkedDocument { get; private set; } = null;
    get { return null != LinkedDocument; }
  public bool AllowElement( Element e )
    return true;
  public bool AllowReference( Reference r, XYZ p )
    LinkedDocument = null;
    Element e = _doc.GetElement( r );
    if( e is RevitLinkInstance )
      RevitLinkInstance li = e as RevitLinkInstance;
      LinkedDocument = li.GetLinkDocument();
      e = LinkedDocument.GetElement( r.LinkedElementId );
    return e is T;
Here is the resulting external command for testing it:
public Result Execute(
  ref string message,
  ElementSet elements )
  UIApplication uiapp = commandData.Application;
  UIDocument uidoc = uiapp.ActiveUIDocument;
  Document doc = uidoc.Document;
  Reference r;
  ElementInLinkSelectionFilter<Room> filter
      doc );
  try
    r = uidoc.Selection.PickObject(
      ObjectType.PointOnElement,
      filter,
      "Please pick a room in current project or linked model" );
  catch( Autodesk.Revit.Exceptions.OperationCanceledException )
  Element e;
  if( filter.LastCheckedWasFromLink )
    e = filter.LinkedDocument.GetElement(
  else
    e = doc.GetElement( r );
  TaskDialog.Show( "Picked", e.Name );
Please let us know whether this works for you as well.
Thank you again, and cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 12 of 12
RPTHOMAS108
Thanks Jeremy,
Yes that is much cleaner and still works from the test I've done.
Regards
Richard
