Picking Regions (split faces)
juancalvoferrandiz
Message 1 of 10
juancalvoferrandiz
Hello everyone,
I'm trying to select regions of split faces as we can do with the paint tool with no positive result.
I use pickobject() method for selecting faces.
http://www.revitapidocs.com/2018.1/0315fd62-b533-1817-2f2d-d9ebd4bc8e33.htm
With GetRegions() I get the list of regions, but I'm not able to neither use a pick system or idetify them by no criteria that is not area or material assignation properties.
http://www.revitapidocs.com/2018.1/9bde5f26-f830-7fca-39aa-792f9ac7caa5.htm
With FaceSplitter I'm not able to think in any option either.
http://www.revitapidocs.com/2018.1/ba55587f-4f1e-7f4c-5b1c-864e10cab304.htm
All comments are wellcome.
Thanks a lot.
Juan.
Replies (9)
Message 2 of 10
pmcmm1
Hi Juan,
You should be able to have the resulting faces with the GetRegions() command, but you will have to use the revit API to work with them I believe. It is rather limited the split faces commands in Revit API.
I am also struggling with a similar problem. I want to divide a wall automatically using facesplitters but I can't seem to find a way to create these elements using the revit API. Any idea?
Thanks.
Pedro
Message 3 of 10
Revitalizer
Reference reference = yourUIDocument.Selection.PickObject(ObjectType.PointOnElement);
if (reference != null)
    Element refElem = yourDocument.GetElement(reference.ElementId);
    PlanarFace planarFace = refElem.GetGeometryObjectFromReference(reference) as PlanarFace;
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 4 of 10
juancalvoferrandiz
Great. Thanks @Revitalizer. I didn't realize in the enum option PointOnElement:
http://www.revitapidocs.com/2015/2d0cbbba-d4ab-84b7-b081-36c14769d82c.htm
@pmcmm1, I hope this solves your problem aswell. If not, please tell me and I will see if I can help you in something.
Have a nice day.
Message 5 of 10
juancalvoferrandiz
@Revitalizer, do you know how I can do the highlight selection with PointOnElement as with Face in ObjectType enum?
It seems  Face ObjectType has the highlight internally implemented while PointOnElement doesn't.
I'm trying around this point of view with no positive  results: https://thebuildingcoder.typepad.com/blog/2010/06/highlight-elements.html
Thanks. Cheers, Juan.
Message 6 of 10
Revitalizer
for display purposes, I sometimes create new elements which I remove after use.
For example, after picking a point in a 2D view, I place a marker consisting of a circle and two lines forming an "x" inside it -just DetailCurves: "This is the point you've jst picked."
I a similar manner, you could create some sort of DirectShape to display a face element of arbitrary geometry.
This could be colorized (view overrides, material).
Since it resides at the same place as the original face, you should move it slightly outwards.
This proxy element is an element by itself, it can be highlighted.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Message 7 of 10
pmcmm1
Hi there Juan,
Great to hear that your problem is fixed. My question is slightly different, I plan to create regions in the external walls by drawing Face Splitter lines in the facade, however I intend to have this done automatically.
I can't seem to find a way to create the FaceSplitter line automatically. I presume you are drawing them manually?
Message 8 of 10
juancalvoferrandiz
Thanks for your solution. Yes, after selection (PickObject operation), I do something similar but with the Namespace Analysis and a SpatialFieldPrimitive.
I like the idea with points, I didn't thought about it. Also maybe inserting a family that its an sphere during 3D work.
What I mean is during a multiple selection process. In summary:
If use ObjectType.Face: During selection the faces are highlighted, so I know which faces I'm selecting. Also an + or - symbol appears to know when I may be repeating selection. I can't select regions.
If use ObjectType.PointOnElement: The faces doesn't higlight during selection process. I don't know which elements I'm selecting until I finish the selection process. I may select two or more times the same face without knowing during selection process. I can select regions.
Thanks for your time.
Message 9 of 10
pmcmm1
In the past, I wrote a code that does the same job but it only requires you to select the wall element. With this code you dont have to use the PointOnElement to get the face, which gives you more flexibility.
    geomOption = app.Create.NewGeometryOptions()
    geomOption.ComputeReferences = True
    geomOption.DetailLevel = ViewDetailLevel.Fine
    geomOption.IncludeNonVisibleObjects = True
    face_dict = dict()
    for wall in walls:
        #code to get the walls from the selection
        geomElem = wall.get_Geometry(geomOption)
        face_dict[wall.Id.IntegerValue]=dict(geometry=geomElem,wall=wall)
        for geomSolid in geomElem:
        	#print geomSolid
        	#if (geomSolid):
            for geomFace in geomSolid.Faces:
                if geomFace.FaceNormal.IsAlmostEqualTo(wall.Orientation) == True:
                    face_dict[wall.Id.IntegerValue]['face']=geomFace
Message 10 of 10
canyon.des
    public class SurfaceSelectionFilter : ISelectionFilter
        public bool AllowElement(Element element)
            return true;
        public bool AllowReference(Reference refer, XYZ point)
            if (refer.ElementReferenceType == ElementReferenceType.REFERENCE_TYPE_SURFACE)
                return true;
            else
                return false;
SurfaceSelectionFilter filter = new SurfaceSelectionFilter();
Reference reference = yourUIDocument.Selection.PickObject(ObjectType.PointOnElement, filter, "please select a Face");
Bruce Hans
