PickElementsByRectangle() throw System.NullReferenceException
denisyukJ
Message 1 of 11
denisyukJ
I would like to follow Revit API developer's guide, but MassSelectionFilter throws me System.NullReferenceException and even doesn't give me chance to select elements with rectangle shape. If I get rid of selFilter as PickElementsByRectangle agrument, selection working fine, but obviously don't filter anything.
public static IList<Element> GetManyRefByRectangle(UIDocument doc)
        ReferenceArray ra = new ReferenceArray();
        ISelectionFilter selFilter = new MassSelectionFilter();
        IList<Element> eList = doc.Selection.PickElementsByRectangle(selFilter,
                "Select multiple faces") as IList<Element>;
        return eList;
public class MassSelectionFilter : ISelectionFilter
        public bool AllowElement(Element element)
        if (element.Category.Name == "Mass")
                return true;
        return false;
        public bool AllowReference(Reference refer, XYZ point)
                return false;
Can some of you give me a hint how to proceed?
BR,
Evgeniy Denisyuk
Replies (10)
Message 2 of 11
jeremy_tammik
Yes, sure. Welcome to the Revit API. Please start by working through the Revit API getting started material, e.g., the My First Revit Plug-in tutorial:
Then, all will become clear.
Message 3 of 11
rvtquestions
Depending on the API version you are working to, you can try testing against the Element Id. Note 2024+ ElementId is no longer just a simple int but a 64bit long format.
public bool AllowElement(Element e)
    return e.Category.Id.IntegerValue.Equals((int)BuiltInCategory.OST_Mass);
    // Again note in 2024+ you will have to handle the Id differently and convert it to an integer on your own since IntegerValue is depreciated.
Message 4 of 11
denisyukJ
Hello, @jeremy_tammik
Thank you for your answer. I already have done that, but unfortunately haven't found any.
Message 5 of 11
Moustafa_K
the null exception might occur for elements that has no category defined.
In short you need to consider there is a probability the category variable might be null
another important aspect. Try as mush as possible to avoid hard coding names literally such as "name== "Mass",
always verify category by its built in id / Category
see the below modified version of your code, hope this helps
        if (element.CanBeHidden == null)
            return false;
        if (element.Category.BuiltInCategory == BuiltInCategory.OST_Mass)
            return true;
        return false;
        return false;
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
Message 6 of 11
denisyukJ
Thanks for all answers, but non of them is not working for me. I guess that problem is null category as @Moustafa_K suggested, but for some reasons I can not even select elements by rectangle properly because program allows me to pick only one point and throw exception right after that.
@Moustafa_K , how I can modify this piece of code because CanBeHidden method contains arg and can not be equal to the null value?
            return false;
Message 7 of 11
Moustafa_K
CanbeHidden needs a view as per the documentation, it is a function that requires a a view, to return a bool
thus the statement needs a bit of alter for example
if(element.CanbeHidden(element.Document.ActiveView))
    // do something
Moustafa Khalil
Message 8 of 11
denisyukJ
Can bool value be null?
Message 9 of 11
Moustafa_K
no it can't be null, I mean for this function it is no. so you need to check the equality if  equals true or false;
Moustafa Khalil
Message 10 of 11
denisyukJ
I healed this by adding small null protection in the beginning, what is still strange for me because exeption throws BEFORE selection.
Any way current filter implementation part looks like this:
        if (element.Category.Name == null)
                return false;
                return true;
        return false;
                return false;
Message 11 of 11
BKSpurgeon
Check out the attachment / docs of the labs which covers selections which @jeremy_tammik  (is probably) referring to. If you want the source code, check out the labs as Jeremy suggests.
But if you want a "quick and dirty" answer check out what I hacked together (untested and no guarantees) - where I want to select family instances.:
private List<FamilyInstance> selectFamilyInstances()
    ISelectionFilter familyInstanceFilter = new SelectionFilterFamilyInstance();
    return app.ActiveUIDocument.Selection
              .PickElementsByRectangle(familyInstanceFilter, "Select all items you want to Dimension")
              .Cast<FamilyInstance>()
              .ToList();
class SelectionFilterFamilyInstance : ISelectionFilter
        return e is FamilyInstance;
    public bool AllowReference(Reference reference, XYZ position)
        return true;
