Pick any point from active view2D
Hey,
I wonder if it is possible to get a point from the plan of the current active 2Dview. Which point it is do not matter it is for calculation only. I don't want to use the PickPoint() method because i don't want the user to select the point.
(I will be able to give the solution to my other post if i get this one !)
Thanks !
you can use the view's crop box corners and its direction vectors / crop box transform to do this fairly easily.
GIve this a try:
XYZ AnyPointOnActiveView= new XYZ(doc.ActiveView.get_BoundingBox(doc.ActiveView).Max.X - doc.ActiveView.get_BoundingBox(doc.ActiveView).Min.X, doc.ActiveView.get_BoundingBox(doc.ActiveView).Max.Y - doc.ActiveView.get_BoundingBox(doc.ActiveView).Min.Y, 0);
Thanks & Regards
Sanjay Pandey
