Pick a face in document, pick same face in familydocument - how?
Hi everyone!
I have searched the Internet for information but didn't found what I needed. That's what bring me here.
I'm trying to create an addin where I need to pick a face in a family through the project.
First question: Is it possible?
I've used Revit Lookup to see if there is any match between the face in the project and the face in the family but I can't find any. It is only the area that matches but that's not good enough for me.
Next question: Can you guys help me?
recepagah12
First, yes it is possible to select a face and get it geometry and information from it via Revit API.
But, I think you are new in the Revit API. So, I suggest you start learning the basics.
Here are some blogs for learning Revit
Autodesk Revit Developer's Guide
Building Coder
AEC Developer Blog
And I strongly suggest you look through the Revit SDK samples.
Finally, I want to show you how to select a face and it is really easy.
Reference reference = uidoc.Selection.PickObject(ObjectType.Face);
Element e = doc.GetElement(reference);
GeometryObject geomObj = e.GetGeometryObjectFromReference(reference);
Face face = geomObj as Face;
double area = face.Area;
I hope this helps,
Have a good day,
Recep.
Hi @recepagah12,
Thanks for your reply.
I made it work before I saw your post. Thanks anyway. 🙂
