PAUSE for user input
rwebb0418
rwebb0418
I am trying to write an addin that will cycle through all of the views (open or not) spell check them and then close all the views with exception of the original view.  Below is the code I've got to date, I can run the spell check on the first view but as soon as it swtiches to the next view it throws an error.
Public Function Execute(ByVal cmdData As ExternalCommandData, ByRef msg As String, ByVal elemSet As ElementSet) As Result Implements IExternalCommand.Execute
_cachedCmdData = cmdData
Try
'Dim uiapp As UIApplication = cmdData.Application
''TODO: add your code below.
MsgBox("Running Spell Check on **ALL** Views")
'collect inital view to restore after spell check
Dim actView As Autodesk.Revit.DB.View = CachedUiApp.ActiveUIDocument.ActiveView
Dim actViewID = actView.Id
'collect all views
Dim views As List(Of ElementFilter) = New List(Of ElementFilter)
views.Add(New ElementClassFilter(GetType(View3D)))
views.Add(New ElementClassFilter(GetType(ViewDrafting)))
views.Add(New ElementClassFilter(GetType(ViewPlan)))
views.Add(New ElementClassFilter(GetType(ViewSection)))
Dim filter As LogicalOrFilter = New LogicalOrFilter(views)
Dim col As FilteredElementCollector
col = New FilteredElementCollector(CachedDoc)
col.WhereElementIsNotElementType()
col.WherePasses(filter)
'parse through views and spell check each one
For Each CurView As Autodesk.Revit.DB.View In col
'MsgBox(CurView.ViewName)
If CurView.IsTemplate = False Then
CachedUiApp.ActiveUIDocument.ActiveView = CurView
CachedUiApp.PostCommand(RevitCommandId.LookupCommandId("ID_CHECK_SPELLING"))
'RaiseEvent <test></test> uiapp.Idling = New EventHandler((IdlingEventArgs), (Onidle()))
Next
'restore intial view and close all others
Dim openViews = CachedUiApp.ActiveUIDocument.GetOpenUIViews()
For Each openView As Autodesk.Revit.UI.UIView In openViews
If openView.ViewId <> actViewID Then
openView.Close()
Next
Return Result.Succeeded
Catch ex As Exception
msg = ex.ToString()
Return Result.Failed
End Try
End Function
Here's the Error I get:
Autodesk.Revit.Exceptions.InvalidOperationException: Revit does not support more than one command are posted.
at Autodesk.Revit.UI.UIApplication.PostCommand(RevitCommandId commandId)
at RevitSpellCheck.SpellCheck.Execute(ExternalCommandData cmdData, String& msg, ElementSet elemSet) in C:\Users\BWebb\Documents\Visual Studio 2010\Projects\RevitSpellCheck\RevitSpellCheck\SpellCheck.vb:line 106
Any suggestions are greatly appreciated.
augusto.goncalves
The PostCommand help file says: "Posts the command to the Revit message queue to be invoked when control returns from the current API context."
So Revit will not execute the command until it get back the focus... maybe you will need to wait until this command is done but watching Idling event.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
rwebb0418
Thanks for the suggestion.
Now for the Noob follow up:  How?
I'm finding events in the Revit API a little confusing.
rwebb0418
As a followup, I've found and added Event handlers as per instructions found here: http://spiderinnet.typepad.com/blog/2011/07/revit-api-and-vbnet-uiapplication-event-implementation-i...
Now however I can't for the life of me figure how I'm to query the handler to watch the idling event.
augusto.goncalves
Most likely you need a control variable: when you send PostCommand, set the control variable to True. The Idling event trigger all the time, but if the control variable is Trua, then you know a PostCommand was triggered and now it's done, so it's time for a new PostCommand.
That a common architecture that works in most scenarios.
Augusto Goncalves
rwebb0418
I'm stymied, for the life of me I can't figure this out.
Public Shared Sub UIAppEvent_Idling_Handler(ByVal sender As Object, ByVal args As EventArgs)
Dim app As Autodesk.Revit.ApplicationServices.Application = TryCast(sender, Autodesk.Revit.ApplicationServices.Application)
Dim uiApp As New UIApplication(app)
Dim specArgs As Autodesk.Revit.UI.Events.IdlingEventArgs = TryCast(args, Autodesk.Revit.UI.Events.IdlingEventArgs)
I can see the event handler starting however it can't assign sender to the app variable. it keeps returning "nothing" and ends the handler code after Dim uiApp as new UIApplicaiton (app) line
rwebb0418
Nevermind I pulled my head out of my **** and figured out the problem.
It's not exactly a pretty solution but I've put the code I wanted to run when idle into the Idle handler and then removed the handler after the last run.
final solution looks like this:
Dim openViews
openViews = SpellCheck.CachedUiApp.ActiveUIDocument.GetOpenUIViews()
If openViews.Count = 1 Then
RemoveHandler ExtApp._cachedUiCtrApp.Idling, AddressOf UIAppEvent_Idling_Handler
SpellCheck.CachedUiApp.PostCommand(RevitCommandId.LookupCommandId("ID_CHECK_SPELLING"))
ElseIf openViews.count > 1 Then
If openView.ViewId <> SpellCheck.actViewID Then
openView.Close()
Exit For
Next
Else
End Sub
