Path reinforcement
Path reinforcement
office
Path reinforcement
office
as working with reinforcements i was trying to create a path reinforcement based on the example code provided by "help"
whatever i do i get that error message:
Exception: pathReinforcementTypeId should refer to an PathReinforcementType element.
Parameter name: pathReinforcementTypeId
but in my opinion i am referring to a PathReinforcementType ????
my programming enviroment is dynamo and i am trying to solve this in ironpython and am a bad programmer........
here is my code:
doc = DocumentManager.Instance.CurrentDBDocument
uiapp = DocumentManager.Instance.CurrentUIApplication
app = uiapp.Application
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
icurves= UnwrapElement(IN[1])
wall=UnwrapElement(IN[0])
curves=[]
for i in icurves:
    start=i.GeometryCurve.GetEndPoint(0)
    end=i.GeometryCurve.GetEndPoint(1)
    curves.append(Line.CreateBound(start,end))
TransactionManager.Instance.EnsureInTransaction(doc)
defaultRebarBarTypeId = doc.GetDefaultElementTypeId(ElementTypeGroup.RebarBarType)
defaultPathReinforcementTypeId = doc.GetDefaultElementTypeId(ElementTypeGroup.PathReinforcementType)
defaultHookTypeId = ElementId.InvalidElementId;
rein = Autodesk.Revit.DB.Structure.PathReinforcement.Create(doc, wall, curves, True, defaultPathReinforcementTypeId, defaultRebarBarTypeId, defaultHookTypeId, defaultHookTypeId);
TransactionManager.Instance.TransactionTaskDone()
#Assign your output to the OUT variable
OUT =rein
tx peter
mikako_harada
Hi Koppevi,
Looks like this issue is very similiar to another post of yours:
http://forums.autodesk.com/t5/revit-api/create-area-reinforcement-by-boundary/m-p/5523536#M8910
Using dynamo certainy narrow the help you can get here.  So again, I would suggest the same:
1. try posting to dynamo discussion forum:
http://dynamobim.com/forums/forum/dyn/
2. if you can reproduce using/modifying the SDK sample or something, we have more people who can take a look.
Sorry for being not much help on this.
Mikako Harada
Developer Technical Services
