Parameters with StorageType:None
BardiaJahan
BardiaJahan
There are some type parameters that need to be changed through window/dialogue boxes such as Wall Type Structure or Dimension Type Units Format. I believe the StorageType for those parameters is None. I am trying to change those values programmatically for family types. Is there any way to get access to them. Even a workaround for any of those would be a great help.
GonçaloFeio1321
Try finding out what they are by ParameterType.
BardiaJahan
I believe they are all of type Invalid.
matthew_taylor
Hi @BardiaJahan,
'Invalid' parameter types are used by Revit and aren't exposed to us via the API.
As of Revit 2017.1, the dimensionType units are accessible:
http://thebuildingcoder.typepad.com/blog/2016/11/whats-new-in-the-revit-20171-api.html#4.3.2
Before that, they're probably not accessible.
To access wall structure layers, you'll need to access those via other than parameters. See Jeremy's topic listing:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.17
The SDK has examples of compound structure component access also.
Cheers,
-Matt
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
BardiaJahan
@matthew_taylor
I have used wall structure API but I was wondering if there is a more generic way to modify these properties. Apparently there is not and many thanks for clarification.
