ParameterFilterElement 2020
BrentBurgess1980
BrentBurgess1980
Hi All,
I am trying to filter rebar and apply a colour to it depending on it's size.  I have noticed that ParameterFilterElement is removed from 2020.
I have having some issues with creating the filter.
  public void CreateFilter(Document doc, View view, double barDiameter)
            // create list of categories that will for the filter
            IList<ElementId> categories = new List<ElementId>();
            categories.Add(new ElementId(BuiltInCategory.OST_Rebar));
            // create a list of rules for the filter
            IList<FilterRule> rules = new List<FilterRule>();
            // This filter will have a single rule for the filter
            Parameter rebarSize = new FilteredElementCollector(doc).OfClass(typeof(Rebar)).FirstElement().get_Parameter(BuiltInParameter.REBAR_BAR_DIAMETER);
            rules.Add(ParameterFilterRuleFactory.CreateLessRule(rebarSize.Id, barDiameter, 0.1));
            ParameterFilterElement filter = null;
            using (Transaction t = new Transaction(doc, "Create and Apply Filter"))
                t.Start();
                filter = ParameterFilterElement.Create(doc, "Thin Wall Filter", categories,rules);
                view.AddFilter(filter.Id);
                t.Commit();
            string filterNames = "";
            foreach (ElementId id in view.GetFilters())
                filterNames += doc.GetElement(id).Name + "\n";
            OverrideGraphicSettings ogs = new OverrideGraphicSettings();
            ogs.SetCutLineColor(new Color((byte)255, (byte)0, (byte)0));
            //ogs.SetCutLineColor(getColour(doc.Application,12));
            using (Transaction t = new Transaction(doc, "Set Override Appearance"))
                t.Start();
                view.SetFilterOverrides(filter.Id, ogs);
                t.Commit();
I think I have the rest of it correct, but can't test unitl I fix the ParameterFilterElement issue.
Can anyone point me in the right direction on how to do this?
Brent
jeremytammik
No, ParameterFilterElement has not been removed in Revit 2020.
What is the problem you see?
Jeremy Tammik
Developer Technical Services
The Building Coder
BrentBurgess1980
Hi @jeremytammik ... Yeah.... The wording wasn't the best on that post.
The above line was the line that was causing issues. It flags an error saying it is obsolete in 2019 and removed in 2020.
I was looking for the new way to set the filters and havent had much luck.
I have been programming in AutoCAD for 15 years, and this is my first foray into the Revit space, so still trying to get my head around it all.
Brent
sragan
I got it to run by adding a few lines of code, and changing "rules" to "elemFilter" in the filter line of code.  Like this:
            List<ElementFilter> elemFilters = new List<ElementFilter>();
					foreach (FilterRule filterRule in rules)
    					ElementParameterFilter elemParamFilter = new ElementParameterFilter(filterRule);
    					elemFilters.Add(elemParamFilter);
		 	LogicalAndFilter elemFilter = new LogicalAndFilter(elemFilters);
                t.Start();
                filter = ParameterFilterElement.Create(doc, "Thin Wall Filter", categories,elemFilter);
Also, make sure you have a view open that shows rebar of the correct diameter.
BrentBurgess1980
Thanks @sragan . That worked well!!
