Panel Schedule Spares copy from one Panel schedule to another Panel schedule
venkatadanarao_onteru
Hii sir,
I have 100 Panel schedules, and I need to assign Spares for all 100 Panel schedules like I have one reference. In Reference Panel Schedule I have 2 phase and 3 phase and single-phase Spare circuits.Please help with this i tried searching APIDocs but i didn't find any Class and Properties ?
@jeremytammik
jeremy_tammik
The best place to start looking for the appropriate API classes and properties is by examining the manually created schedule using RevitLookup and other API-based database exploration tools, cf.,
How to research to find a Revit API solution:
The standard approach to research how address a task programmatically goes like this:
  • Set up your BIM manually in the UI
  • Perform the required modification manually in the UI
  • Analyse the resulting changes in the Revit database in the elements, their properties and relationships using RevitLookup and other db exploration tools
The knowledge of the manual modification steps and the resulting db changes will help determine how to achieve the same programmatically.
So, how do you create the desired spares manually in the UI?
Hii Sir,i'm using following methode to add spares
I'm facing error like below if i'm running python script for adding spares.Please help and could you please explain where i'm doing mistake sir.
import clr
clr.AddReference('RevitAPI')
clr.AddReference('RevitServices')
from Autodesk.Revit.DB import *
from Autodesk.Revit.DB.Electrical import *
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
doc = DocumentManager.Instance.CurrentDBDocument
def create_panel_filter(panel_name):
    param_provider = ParameterValueProvider(ElementId(BuiltInParameter.PANEL_SCHEDULE_NAME))
    filter_rule = FilterStringRule(param_provider, FilterStringEquals(), panel_name, False)
    element_filter = ElementParameterFilter(filter_rule)
    return element_filter
def create_panel_filter1(panel_name1):
    filter_rule = FilterStringRule(param_provider, FilterStringContains(), panel_name1, False)
panel_name = "DB1"
panel_name1 = "TOOL"
filter = create_panel_filter(panel_name)
filter1 = create_panel_filter1(panel_name1)
source_schedule = FilteredElementCollector(doc).OfClass(PanelScheduleView).WherePasses(filter).FirstElement()
DES_schedule = FilteredElementCollector(doc).OfClass(PanelScheduleView).WherePasses(filter1).FirstElement()
TransactionManager.Instance.EnsureInTransaction(doc)
table_data = source_schedule.GetTableData()
# Get the number of rows and columns in each section
body_section = table_data.GetSectionData(SectionType.Body)
body_rows = body_section.NumberOfRows
body_cols = body_section.NumberOfColumns
l=[]
for row in range(body_rows):
    for col in range(body_cols):
        value = source_schedule.IsSpare(row, col)
        l.append(value)
        if value is True:
            if col < body_cols:  # Ensure column number is valid
                DES_schedule.AddSpare(row,col)
TransactionManager.Instance.TransactionTaskDone()
OUT = l
ERROR is "Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed.
Traceback (most recent call last):
File "<string>", line 46, in <module>
Exception: The given column number nCol is invalid in Body.
Parameter name: nCol"
Someone please help with this
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
