Paint ModelText's face via revit 2015 API
I'm trying to paint ModelText's face via the APIs and there are some erros in doc.Paint(modelText.Id, face, elementId). But I ever try to paint the FamilyInstance and Wall's face by using the same way is ok. If revit doesn't open  ModelText's Transaction document ?  Any guidance would be appreciated.
Nicky
// Paint the E_path's face
public void PaintModelTextFaces(ModelText modelText, ElementId elementId)
       Document doc = modelText.Document;
       Autodesk.Revit.DB.Options opt = new Options();
       Autodesk.Revit.DB.GeometryElement geomElem = modelText.get_Geometry(opt);
       foreach (GeometryObject geomObj in geomElem)
               if (geomObj is Solid)
                    Solid f = geomObj as Solid;
                    foreach (Face face in f.Faces)
                          using (Transaction trans = new Transaction(doc))
                                 trans.Start("PaintModelTextFaces");
                                 doc.Paint(modelText.Id, face, elementId);
                                 trans.Commit();
Mustafa.Salaheldin
For 2 days long I couldn't realize why on earth your code is not working till god shows me the way.
Here is the complete code that makes it work
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS2
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtCmd : IExternalCommand
        #region Cached Variables
        private static ExternalCommandData _cachedCmdData;
        public static UIApplication CachedUiApp
            get
                return _cachedCmdData.Application;
        public static RvtApplication CachedApp
            get
                return CachedUiApp.Application;
        public static RvtDocument CachedDoc
            get
                return CachedUiApp.ActiveUIDocument.Document;
        #endregion
        #region IExternalCommand Members
        public Result Execute(ExternalCommandData cmdData, ref string msg, ElementSet elemSet)
            _cachedCmdData = cmdData;
            try
                //TODO: add your code below.
                FilteredElementCollector modelTexts = new FilteredElementCollector(CachedDoc).OfClass(typeof(ModelText));
                FilteredElementCollector materials = new FilteredElementCollector(CachedDoc).OfClass(typeof(Material));
                var matByName = from material in materials
                                    where(material.Name == "Acoustic Ceiling Tile 24\" x 48\"")
                                   select material;
                ModelText modelText = (ModelText)modelTexts.FirstElement();
                Material mat = (Material)matByName.FirstOrDefault();
                PaintModelTextFaces(modelText, mat.Id);
                return Result.Succeeded;
            catch (Exception ex)
                msg = ex.ToString();
                return Result.Failed;
            // Before acquiring the geometry, make sure the detail level is set to 'Fine'
            Options geoOptions = new Options();
            geoOptions.DetailLevel = ViewDetailLevel.Fine;
            // Obtain geometry for the given Wall element
            GeometryElement geoElem = modelText.get_Geometry(geoOptions);
            using (Transaction trans = new Transaction(CachedDoc))
                IEnumerator<GeometryObject> geoObjectItor = geoElem.GetEnumerator();
                while (geoObjectItor.MoveNext())
                    // need to find a solid first
                    Solid theSolid = geoObjectItor.Current as Solid;
                    if (null != theSolid)
                        foreach (Face face in theSolid.Faces)
                            using (SubTransaction st = new SubTransaction(CachedDoc))
                                st.Start();
                                CachedDoc.Paint(modelText.Id, face, elementId);
                                st.Commit();
                trans.Commit();
        #endregion
Please if this reply satisfies your need don't forget to mark it as an answer with bunch of kudo
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
Mustafa.Salaheldin
For 2 days long I couldn't realize why on earth your code is not working because it is totaly correct.
It is just the way Revit orders it transactions.
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.IO;
#endregion
            get
            get
            get
        #endregion
            try
                                   select material;
                                st.Start();
                                st.Commit();
                trans.Commit();
        #endregion
Please if this reply satisfies your need don't forget to mark it as an answer.
¯\_(ツ)_/¯
Mustafa Salaheldin
Mustafa.Salaheldin
Here you are the solution
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.IO;
#endregion
            get
            get
            get
        #endregion
            try
                                   select material;
                                st.Start();
                                st.Commit();
                trans.Commit();
        #endregion
¯\_(ツ)_/¯
Mustafa Salaheldin
FrankHolidaytoiling
Can I make new family instances or duplicate the modeltext to place it in a project ?
Maybe i have to use this?
            ElementTransformUtils.CopyElement(CachedDoc, pickedObj.ElementId, xyz);
FrankHolidaytoiling
only u need the users to keep a copy of the model text, still i will do some reclining after that one ...ahhh
