Paint a splitface with C# code
I want to read from a file that had a wall element id and a way to indentify a particular spliface element and paint it with a material. But, I don't know how to identify a splitface element since the API treats it as a face with no element id.
Aaron.Lu
There is no such API to identify a split face. I can only suggest using face's Origin, Area, Computed Normal to ID it. if there is still duplications, you will need to identify more properties..
Aaron Lu
Developer Technical Services
Autodesk Developer Network
hey aron, I'm trying to do that but came across some comlications. I'm currently using revit 2014 and don't have an origin method in the face api. I can't really use are because i'll have multiple splitfaces. I'm trying to use the computenormal but i'm not sure I understand the api. can you give me some sample code to use the compute normal method.
Aaron.Lu
Get computed normal example
PlanarFace face;
var origin = face.Origin;
var normal = face.ComputeNormal(new UV(origin.X, origin.Y));
Aaron Lu
