Overlapping area of two CurveLoops (from floors)
wouter.hilhorst
wouter.hilhorst
I`m working with the revit api in C#. I want to find the intersection between two closed CurveLoops in the XY plane. This intersection should be a third Curveloop in the same plane.
With this I want to find the overlapping surface of the surfaces formed by the lineloops before I use these lineloops to place elements (floors) in Revit. I found the Intersect Method, but this only seems to work on curves.
Is there a way to do this with the revit api?
Wouter
jeremy_tammik
Yes. The Revit API does not provide any support for 2D Boolean operations between curve loops, so you will need to make use of an additional third-party library for that, or implement your own algorithm. The Building Coder shares some suggestions here:
