Orient view to face
Orient view to face
_Vijay
Orient view to face
_Vijay
Actually, i am duplicating Python code into C#. It works but the view always inverting the 3d views.
here is the pyRevit Python code
from pyrevit import HOST_APP
from pyrevit import revit, DB, UI
from pyrevit import forms
def reorient():
    face = revit.pick_face()
    if face:
        with revit.Transaction('Orient to Selected Face'):
            # calculate normal
            if HOST_APP.is_newer_than(2015):
                normal_vec = face.ComputeNormal(DB.UV(0, 0))
            else:
                normal_vec = face.Normal
            # create base plane for sketchplane
            if HOST_APP.is_newer_than(2016):
                base_plane = \
                    DB.Plane.CreateByNormalAndOrigin(normal_vec, face.Origin)
            else:
                base_plane = DB.Plane(normal_vec, face.Origin)
            # now that we have the base_plane and normal_vec
            # let's create the sketchplane
            sp = DB.SketchPlane.Create(revit.doc, base_plane)
            # orient the 3D view looking at the sketchplane
            revit.active_view.OrientTo(normal_vec.Negate())
            # set the sketchplane to active
            revit.uidoc.ActiveView.SketchPlane = sp
        revit.uidoc.RefreshActiveView()
curview = revit.active_view
if isinstance(curview, DB.View3D):
    reorient()
else:
    forms.alert('You must be on a 3D view for this tool to work.')
and here my C#
using System;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
namespace MyPlugin
    [Transaction(TransactionMode.Manual)]
    public class OrientView : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIDocument uiDoc = commandData.Application.ActiveUIDocument;
            Document doc = uiDoc.Document;
            // Ensure the active view is a 3D view
            View3D currentView = uiDoc.ActiveView as View3D;
            if (currentView == null)
                TaskDialog.Show("Error", "You must be in a 3D view to use this tool.");
                return Result.Failed;
            try
                // Prompt the user to select a face
                Reference faceReference = uiDoc.Selection.PickObject(ObjectType.Face, "Select a face to orient the view");
                if (faceReference == null) return Result.Cancelled;
                // Get the selected face
                GeometryObject geometryObject = doc.GetElement(faceReference).GetGeometryObjectFromReference(faceReference);
                PlanarFace selectedFace = geometryObject as PlanarFace;
                if (selectedFace == null)
                    TaskDialog.Show("Error", "The selected face is not planar.");
                // Compute the normal vector and create a plane
                XYZ faceNormal = selectedFace.ComputeNormal(new UV(0, 0));
                XYZ faceOrigin = selectedFace.Origin;
                Plane basePlane = Plane.CreateByNormalAndOrigin(faceNormal, faceOrigin);
                using (Transaction trans = new Transaction(doc, "Orient to Selected Face"))
                    trans.Start();
                    // Create a SketchPlane
                    SketchPlane sketchPlane = SketchPlane.Create(doc, basePlane);
                    // Orient the view to the face
                    OrientViewToNormal(currentView, faceNormal, faceOrigin);
                    // Set the SketchPlane to the active view
                    currentView.SketchPlane = sketchPlane;
                    trans.Commit();
                // Refresh the view
                uiDoc.RefreshActiveView();
                return Result.Succeeded;
            catch (OperationCanceledException)
            catch (Exception ex)
                message = ex.Message;
        /// <summary>
        /// Orients the active 3D view to the given normal vector and origin.
        /// </summary>
        private void OrientViewToNormal(View3D view, XYZ normal, XYZ origin)
            // Reverse the normal to align with the face
            XYZ viewDirection = normal.Negate();
            // Calculate a valid up direction for the view
            XYZ upDirection = viewDirection.CrossProduct(XYZ.BasisX);
            if (upDirection.IsZeroLength())
                upDirection = viewDirection.CrossProduct(XYZ.BasisY);
            // Set the view orientation
            ViewOrientation3D orientation = new ViewOrientation3D(origin, upDirection.Normalize(), viewDirection.Normalize());
            view.SetOrientation(orientation);
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
jeremy_tammik
Here is a C# sample that orients a section view to align exactly with a given face:
