I'm sure we are all tired of moving sheets around in a PDF after printing our sets (move the General sheets to the top, then put the demo and site sheets in their orders, etc). I have an add in that will create sheet sets for revisions, and I figured that I could use this to finally put the sheets in the order that I want them to print. Alas the ViewSet.Insert() method seems to sort as it adds the sheets because the order in the ViewSet ends up different than the order that I insert the sheets (boo!). O I am thinking there are 2 alternatives:
- Create my own Sheet Number parameter and use it on my titleblock and use the Revit sheet Number BIP as a sequential print order
- Create my own print routine and dialog that will use my own sheet lists rather than the ViewSheetSets that Revit stores for us (I'm thinking to use global parameters to allow these lists to be stored and accessed again).
Obviously 2 is far more work, but perhaps could work and provide a lot of flexibility that may not be present in Revit. But before I start down this path I wanted to get input from the community. Has anyone else come up with a solution for this?
