Opne New family file via API
Hello all,
I am currently trying to automatically open a family file from local folder (here is my code):
public void OpenFamily(ExternalCommandData commandData)
    UIApplication uiapp = commandData.Application;
    bool hasOpenedFile = this.HasOpenedFile(uiapp);
    string path = "";
    if (hasOpenedFile)
        System.Windows.MessageBox.Show("Please close the current project before importing a family!");
    else
        string fileImportPath = "file path here"
        UIDocument doc = uiapp.OpenAndActivateDocument(fileImportPath);
private bool HasOpenedFile(UIApplication uiapp)
    if (uiapp.ActiveUIDocument != null)
       return true;
    return false;
If I open a Revit and try to open the file, everything works fine. The problem occurs if before that I had another family/project opened and after closing it I try to open the current family (actually there is no longer an active document).
The exception thrown is here OpenAndActivateDocument(fileImportPath) with message : "An unhandled exception of type 'System.InvalidOperationException' occurred in PresentationFramework.dll
Additional information: BuildWindowCore failed to return the hosted child window handle.
Any ideas what may cause the problem and how can I fix it?
Thanks!
jeremytammik
You are probably doing something wrong.  🙂
Maybe it will work better if you open the new family before closing the old one.
When you close the last family, Revit has to move to a zero-document state.
That may change things more than when some document remains open.
We ran into a couple of issues in the past closing the last active document:
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi Jeremy,
Thanks for your replay 🙂 Actually now I simplified it to just having a family open and trying to open anotherone trough the API and the same problem accures...
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
    UIDocument doc = uiapp.OpenAndActivateDocument("pathToFileHere");
    return Result.Succeeded;
Again if first thing when openig revit is loading the family trough the API, it works fine.
