Openings Boundary
Openings Boundary
Openings Boundary
Dear All,
Autodesk.Revit.DB.Openings have a property called BoundaryCurves. But after some time I realized it doesn’t only return the boundary (as one should believe) but also the symbolic lines within the opening. For example: the opening sketch is defined by a rectangle which is then being crossed out by symbolic lines for annotative reasons. In order to distinguish between them I figured that symbolic lines have line styles while the actual opening sketch lines don’t. But once I’m walking through, all of the lines have the StyleId -1 applied. My next approach was to try to apply a line style to all lines and hope for an exception to be thrown on opening sketch lines. Which sadly didn’t happen.
So my question is how can I distinguish between opening sketch lines (the actual boundary) and symbolic lines within?
Using Revit2016 & 2017.
Thanks for your Help,
Max
JimJia
We checked the document you provided, unfortunately however it is hard to us to find a clue how to recreate this problem. In order to diagnose, could you isolate your test project and send us a small, reproducible sample? Note, please do not send us any information you think are confidential to your company. We appreciate your understanding and your patience again!
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
Thanks, I attached the file.
Max
JimJia
Hi Maximilian Thumfart,
I can reproduce your case and I already create Revit issue REVIT-100343 to track this, engineering team will review and evaluate this, I will keep you updated on any progress.
This issue needs to be assessed by our engineering team, and prioritized against all of the other change requests that are outstanding. As a result any information that you can provide to influence this assessment will help. Please provide the following where possible:
• Impact on your application and/or your development.
• The number of users affected.
• The potential revenue impact to you.
• The potential revenue impact to Autodesk.
• Realistic timescale over which a fix would help you.
• In the case of a request for a new feature or a feature enhancement, please also provide detailed Use Cases for the workflows that this change would address.
This information is extremely important. Our engineering team have limited resources, and so must focus their efforts on the highest impact Change Requests. We do understand that this will cause you delays and affect your development planning, and we appreciate your cooperation and patience.
Jim Jia
