Open .rfa file to edit it
Yonas89
Yonas89
Hello, I am stuck  a bit with this.
What would be the process to  open family file and make edit to it? By using the snippet below I get the following error: "starting a transaction from an external application running outside of API context is not allowed" And though I totally understand that I am trying to access it from outside, I have no clue what to do to access it right.  Thank you in advance!
 private void GetBfAndDfromRevit(Autodesk.Revit.ApplicationServices.Application app)
            string path = ArticalNumberList.GetPath(articularTxtBox.Text);
            //Open Revit Family File in a separate document
            if(path!="")
                Document revDoc = app.OpenDocumentFile(path);
                //Get the familyManager instance from the open document
                FamilyManager mgr = revDoc.FamilyManager;
                using (Transaction tx = new Transaction(revDoc))
                    tx.Start("addtype");
                    if (mgr.Types.Size == 0)
                        mgr.NewType("Type 1");
                    tx.Commit();
jeremytammik
I answered an almost identical question this very morning:
https://stackoverflow.com/questions/52161965/revit-api-how-to-make-a-external-command-run-asynchrous...
The Revit API can only be used within a valid Revit API context, and such a context is provided exclusively by Revit events:
http://thebuildingcoder.typepad.com/blog/2015/08/revit-api-context-and-form-creation-errors.html#2
http://thebuildingcoder.typepad.com/blog/2015/12/external-event-and-10-year-forum-anniversary.html#2
You can however implement an external event and trigger that from outside to obtain access to a valid Revit API context. This is discussed in detail with many solutions provided by The Building Coder in the topic group on Idling and External Events for Modeless Access and Driving Revit from Outside:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.28
Another approach might be to make use of the DocumentOpened Event:
https://apidocs.co/apps/revit/2019/7e5bc7a1-0475-b2ec-0aec-c410015737fe.htm
You could use that to trigger the execution flow you desire.
I would start out reading the numerous solutions listed in the topic group, and probably end up making use of an external event.
Good luck and have fun!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
jeremytammik
Just implement a normal external command and do the job inside its Execute method.
Jeremy Tammik
The Building Coder
Yonas89
@jeremytammik,
thanks a lot !
