Open in Twinmotion from Revit 2024
ashraquet_bastawrous
Hi everyone,
I am working on a model in Revit 2024, I have used (open in Twinmotion) few times to check that each wall and element has a different material, I have tried also this morning to check and it was working just fine.
suddenly, it didn't work at all after I ''saved as'' my Revit file, i press on "open in TM'' but nothing happens, closed and turned off my laptop and then opened again, it opens but it doesn't link the direct link still.
I have checked my interned, it is going through, i downloaded some megascan files, I even changed the name of the file, tried to open other previous versions of the files but nothing works, nothing opens in TM, tried to import direct link but it shows no options.
Can you help me please?
jeremy_tammik
Afaict from your query, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface.
In that case, you will probably get more optimal answers to a question like yours relating to product usage and other end-user support issues in one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
Best regards,
Jeremy
Thank you for the note, it was unintentional mistake, I will post in the dedicated forums.
thanks again
