Open external file (Hyperlink)
IgBorges
IgBorges
Hi
I need open a file Excel through Revit. Similar to hyperlink.
What click the button, it opens the file. (Sorry, my english, i'm from Brazil :D)
Thanks!
This is the code, but does not work:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Linq;
using System.Net;
using System.Windows.Forms;
using System.Windows.Threading;
using System.Data.OleDb;
using System.Diagnostics;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
[TransactionAttribute(TransactionMode.Manual)]
[RegenerationAttribute(RegenerationOption.Manual)]
    public class OpenExcelTesoura : IExternalCommand
        static void Main()
            OpenMicrosoftExcel(@"X:\Biblioteca\06 - REVIT\Componentes Revit\Damiani\Estrutural\Treliças\TESOURAS DAMIANI.xlsm");
        static void OpenMicrosoftExcel(string f)
            ProcessStartInfo startInfo = new ProcessStartInfo();
            startInfo.FileName = "WINEXCEL.EXE";
            startInfo.Arguments = f;
            Process.Start(startInfo);
Joe.Ye
Note sure which version of Excel you are using,.
For Excel 2010, the executable file name is excel.exe, but not the winexcel.
This works fine in my side.
            startInfo.FileName = "EXCEL.EXE";
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
