Obtain quantity sum of instances of type Revit API C#
rita.aguiar
rita.aguiar
Is it possible to obtain the quantity sum of all instances of a type through the Revit API?
Any help would be appretiated.
In similarity to what this schedule is obtaining:
BenoitE&A
I guess so :
- you can filter your model the same way you do it in your Schedule (FilteredElementCollector, ofCategory, Where, etc...)
- you can evaluate the value of your given parameter for every Instance in this collector
- you can sum these.
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
rita.aguiar
@BenoitE&A
Ah, what a pity. Is that the best way? I was hoping I could find a property that would return the sum so I didn't have to do it myself.
Thanks for the reply.
BenoitE&A
We gave it a thought with my associate and did not come with anything simpler. But frankly, it's not top-notch... really the same as creating a schedule...
Benoit FAVRE
john_dalessandro
Because LINQ lazy loads, the following should only run through each element once and be pretty quick.
return new FilteredElementCollector(doc)
    .OfCategory(/* category */)
    .Sum(e => e.get_Parameter(/* parameter */).AsDouble());
