Obtain Generic Appearance Color on MEP Curve Objects
pmeigneux
pmeigneux
Hello everybody,
I would like to obtain the generic appearance color on the MEP curve objects. At this time, I only succeed to retrieve this information on the surface element by using this sample of code.
      private Color GetAppearenceColor(Document doc, Face face)
            Color appearenceColor = Color.InvalidColorValue;
            Material material = doc.GetElement(face.MaterialElementId) as Material;
            AppearanceAssetElement appearanceElem = material.Document.GetElement(material.AppearanceAssetId) as AppearanceAssetElement;
            Asset theAsset = appearanceElem.GetRenderingAsset();
            AssetProperty colorProperty = theAsset["generic_diffuse"];
            Type type = colorProperty.GetType();
            object apVal = null;
            try
                // using .net reflection to get the value
                var prop = type.GetProperty("Value");
                if (prop != null &&
                    prop.GetIndexParameters().Length == 0)
                    apVal = prop.GetValue(colorProperty);
                else
                    apVal = "<No Value Property>";
            catch (Exception ex)
                apVal = ex.GetType().Name + "-" + ex.Message;
            if (apVal is DoubleArray)
                var doubles = apVal as DoubleArray;
                byte r = (byte)(doubles.get_Item(0) * 255);
                byte g = (byte)(doubles.get_Item(1) * 255);
                byte b = (byte)(doubles.get_Item(2) * 255);
                appearenceColor = new Color(r,g,b);
            return appearenceColor;
Could help us to find a similar approach to get this color information on the MEP curve elements?
Thanks for your help,
Philippe
JimJia
Dear Philippe,
You can get the material of MEP Curve using Element.GetMaterialIds() or Category.Material.
please see codes below:
private Color GetAppearenceColor(Document doc, Element element)
            ICollection<ElementId> ids = element.GetMaterialIds(false);
            MEPCurve mep = element as MEPCurve;
            if (ids.Count > 0)
                Material material = doc.GetElement(ids.ElementAt(0)) as Material;
                //You can also use Category.Material
                //Material material = mep.Category.Material;
                try
                    if (prop != null && prop.GetIndexParameters().Length == 0)
                    else { apVal = "<No Value Property>"; }
                    appearenceColor = new Color(r, g, b);
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
JimJia
Dear Philippe,
            if (ids.Count > 0)
                try
Jim Jia
