Object Reference not set to instance of an object
Moshe-A
Mentor Mentor
Moshe-A
Hey Guys
In my current application i populate 2 detail items + a spot coordinate on some views (selected from a form)
while testing the app some times i'm getting the exception in the title but some times not and today i decided to explore it and came to this conclution:
the exception is thrown by Revit API
case 1:
starts Revit, open an existing model, invoke my app command, select a view (or some view for populate) and the 2 detail items family are already loaded in the model, the app works fine.
case 2:
start Revit, open an existing model, delete any existing instances of my detail items, purge the detail items from the database and then invoke my app command, select a view Bom i'm getting the exception. to recover from this i just draw some thing a wall or even a line and the app works.
i enter deep in the code to find from where the exception is coming and it's the view collector.
it seems that after purging the detail items the new created view collector has garbage
does any one here familer with this and has a workaround?
(i am working with R2015 and still do not know what going up)
thanks in advance
Moshe
Mustafa.Salaheldin
Can you provide a sample code?
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
MarryTookMyCoffe
i know that rooms stays in memory, that for sure, maby something else too, try check if something isValidObject before you use it.
do not worry it only gonna take Autodesk 5 years to fix bug
Revitalizer
may it be that the FamilySymbol you use for placing detail items is not active yet?
In this case it would need to be activated before placing instances.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
shailkolhe.55
Community Visitor
Community Visitor
Error initialising document revised 30jan 20
description object reference not set an instance of an object
when I live since to lumion
