Object coordinates different between model and my code.
anhtrung
anhtrung
i want to get coordinates for structural column but i see that different between model and my code, you can see attached image below.
Kevin.Bell
The code is probably reporting against the Project Basepoint whereas your Spot coordinate probably is displaying coordinates based on the Survey point.
Also, any coordinate information retrieved by code will be in decimal feet - you'll need to convert to what every units your using...
