object above cut plane
sakar_deepak
sakar_deepak
Attached are images and Revit file 2019.
This is about the stepped auditorium floor rising from 2nd floor to 3rd floor. Revit shows the full length of stepped flooring on 3rd floor plan; which is okay.
The problem is that the stepped floor should be visible only half on 2nd floor plan but it shows the full.
I modeled a generic floor based extruded stepped floor family and inserted in project.
Regards
Deepak Gupta
Architect
(...... those, who are answering the problems in community forum here, are great people .....)
jeremytammik
Dear Deepak,
Are you doing anything programmatically, or just using the standard Revit user interface?
If you are not doing anything programmatically, please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
sakar_deepak
okay, thanks for right direction.
Regards
Deepak Gupta
Architect
