NWC Export doesn't throw errors, but won't actually export anything...?
I have this script i'm making for my pyRevit extension that bulk exports NWCs. Esstentially, if there's a view with "NAVIS_" in the name, it uses my preselected settings and exports files to a directory. I currently have a lot of print statements for debugging and zero user input for the sake of just trying to get this thing to work. I even removed all my options in this most recent try and defaulted to whatever options come as default.
I'm stumped because it's not throwing any errors, but the export is failing. I've tinkered with it for a couple hours trying to get it to work, but to no avail. Can someone throw me a bone please?! What am I doing wrong?
# !python3
import clr
clr.AddReference('RevitAPI')
clr.AddReference('RevitServices')
clr.AddReference('RevitNodes')
from Autodesk.Revit.DB import *
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
import os
from datetime import datetime
# Initialize the current document
doc = __revit__.ActiveUIDocument.Document # type: ignore
# Function to export views containing "NAVIS_" in their name
def export_navis_views():
if not OptionalFunctionalityUtils.IsNavisworksExporterAvailable():
print("Navisworks exporter is not available. Please install the necessary functionality.")
return
else:
print("Navisworks Exporter installation files are installed...\nProceeding")
today = datetime.now().strftime("%Y-%m-%d")
print("\nStarting export_navis_views function")
# Get all views in the project
views_in_doc = FilteredElementCollector(doc).OfClass(View3D).ToElements()
print(f"\tFound {len(views_in_doc)} views in the document")
# Filter views with "NAVIS_" in the name
navis_view_elements = [view for view in views_in_doc if "NAVIS_" in view.Name]
print(f"\nnavis_view_elements = {navis_view_elements}")
print(f"\tFiltered {len(navis_view_elements)} views containing 'NAVIS_' in the name")
# Set up Navisworks export options
options = NavisworksExportOptions()
options.ConvertElementProperties = True
options.ConvertLights = True
options.ConvertLinkedCADFormats = True
options.Coordinates = NavisworksCoordinates.Shared
options.DivideFileIntoLevels = True
options.ExportElementIds = True
options.ExportLinks = True
options.ExportParts = True
options.ExportRoomAsAttribute = True
options.ExportRoomGeometry = True
options.ExportScope = NavisworksExportScope.View
options.ExportUrls = True
options.FacetingFactor = float(1.0)
options.FindMissingMaterials = True
options.Parameters = NavisworksParameters.All
print(f"Options: {options}")
# Directory to save the exported NWC files
export_dir = "C:\\Users\\rjohnston\\Documents\\05_In-Progress-Content"
print(f"\nexport_dir = {export_dir}")
if not os.path.exists(export_dir):
print("\tDirectory Path Entered Does Not Exist.")
return
else:
print("\tDirectory exists. Proceeding with export...")
# Start transaction
t = Transaction(doc, "Bulk Export to NWC")
t.Start()
try:
# Export each view
for view in navis_view_elements:
try:
# Create file path
file_name = f"{view.Name}_{today}"
print(f'\nPreparing to export view: {view.Name} with file name: {file_name}')
# Export view to NWC
doc.Export(export_dir, file_name, NavisworksExportOptions())
print("Exported Executed.")
except Exception as e:
print(f"\tException occurred while exporting {view.Name}: {e}")
t.RollBack()
return
print(f"\tTransaction Failed: {e}")
t.RollBack()
return
# End transaction
t.Commit()
print("\n\nTransaction Committed")
# Call the function to export Navisworks views
print("Script execution completed")
Here's the pyrevit window after it prints:
