Number Risers Parameter
I have the problem that I cannot see the response of the parameter Number of Risers (StorageType Integer) for the laddder. this is the code
string GetParameterValueString(Element e, BuiltInParameter a)
Parameter p = element.get_Parameter(a);
string z = string.Empty;
if (null != p)
switch (p.StorageType)
case StorageType.Integer:
z = p.AsInteger().ToString();
break;
z =  "=" + z;
return z;
I get nothing as an answer, I appreciate your help
markjvlampad
try this.
Parameter p = e.get_Parameter(BuiltInParameter.STAIRS_ACTUAL_NUM_RISERS);
it doesn't work either
