Novice Question | Failed to initialize the add-in
Failed to initialize addin getelementid because the classs IExternalCmds.GetElementId cannot be found in addin assembly. the full class name provides the entry point for Revit to call the add-in ,You must ensure this classimplements the autodesk.revit.UI.IExternalCommand interface
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
1)In your code, make sure you implemented IExternalCommand interface.
for example Like this
    namespace Lab1PlaceGroup
    public class Class1 : IExternalCommand
     move your cursor over the IExternalCommand and select potential fixes and click Implement interface.
2)when you have done everything perfectly as per the above suggestion, then the problem may lie in your add-in file.
     In your Addin file full class name should be like this <FullClassName>Lab1PlaceGroup.Class1</FullClassName>
      (i.e)
        <FullClassName>namespaceName.ClassName</FullClassName>
I hope that the above suggestion helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
