Not able to change width of layer of compound structure of roof?
I tried several ways to change width of layer of roof, but no luck, here is my code, and attachment if my sample file:
    [TransactionAttribute(TransactionMode.Manual)]
    public class Class1 : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            var doc = commandData.Application.ActiveUIDocument.Document;
            ExtrusionRoof filteredElement = null;
            var filteredElementFilter = new ElementClassFilter(typeof(ExtrusionRoof));
            FilteredElementCollector filteredElements = new FilteredElementCollector(doc);
            filteredElements = filteredElements.WherePasses(filteredElementFilter);
            using (Transaction transaction = new Transaction(doc))
                try
                    if (transaction.Start("update roof width") == TransactionStatus.Started)
                        foreach (ExtrusionRoof element in filteredElements)
                            var elementType = doc.GetElement(element.GetTypeId()) as RoofType;
                            if (elementType != null)
                                var cs = elementType.GetCompoundStructure();
                                var layers = cs.GetLayers();
                                foreach (var layer in layers)
                                    layer.Width = 0.0328; //10mm, not work
                                    break;
                                //cs.SetLayerWidth(0, 0.0328); // not work
                                //cs.SetLayers(layers); // not work
                                break;
                        transaction.Commit();
                    else
                        TaskDialog.Show("ERROR", "Start transaction 'update roof width' failed!");
                catch (Exception ex)
                    TaskDialog.Show("ERROR", ex.ToString());
                    if (transaction.GetStatus() == TransactionStatus.Started)
                        transaction.RollBack();
            return Result.Succeeded;
naveen.kumar.t
Autodesk Support
Autodesk Support
HI @Anonymous,
Refer the below link to update the compound structure layers
Update Compound Structure Layer
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thanks for your reply.
but unfortunately, I tried the api in Revit 2016, it doesn't work.
there is the code im using, none of the indices I tried is useful:
 (For wall, it throws for some of the index, for extrusion roof, no exception but also no change)
var newWidth = 0.00328; // 10mm
var idx = cs.GetFirstCoreLayerIndex();
var idx2 = cs.GetCoreBoundaryLayerIndex(ShellLayerType.Exterior);
var idx3 = cs.GetCoreBoundaryLayerIndex(ShellLayerType.Interior);
var ii = idx;
try
        cs.SetLayerWidth(ii, newWidth);
        ii++;
    TaskDialog.Show("ERROR", string.Format("{0} \r\n   {1}\r\nidx1-3: {2},{3},{4}\r\nlayers count:{5}", ex.Message, ii, idx, idx2, idx3, layers.Count));
