NewFlexDuct Method bugs
frederic.lecuyer
frederic.lecuyer
I wanted to create a code to quickly connect air terminal to a duct using a flexduct because it is a task i was going to repeat often in the next few days. I figured I would use the NewFlexDuct method taking 2 connectors and a FlexDuctType as arguments : http://www.revitapidocs.com/2017/0910f241-d976-2ee8-496d-268a44725d13.htm
While writing my code I made a mistake, trying to connect a flexduct to the same connector, as follow
            Transaction t1 = new Transaction(doc,"Add Round Flex Duct");
            t1.Start();
            try
                doc.Create.NewFlexDuct(conn1,conn1,flexDuctType);
            catch
            t1.Commit();
I was expecting nothing to happen because the method would throw an exception.
However the Revit Application crashed without any notification. In my opinion it is a bug that should be corrected by throwing an exception.
Also I noted that the flex duct is not connected on both ends. The end connecting with the air terminal is not physically connected so I have to add additionnal lines of code to use the method ConnectTo of the Connector Class : http://www.revitapidocs.com/2017.1/04ee99c9-f411-aabe-7b87-013a6f9adb1d.htm
Can anyone try it and validate if it's a Revit bug or a bug with my air terminal family?
Thank you,
Fred
jeremytammik
Dear Fred,
Thank you for your report.
It sounds as if this problem should be easy to reproduce reliably in a minimal test model.
Can you please provide a complete minimal reproducible case for the development team to analyse?
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Thank you!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
