NewAlignment to align family instance reference plane with reference line
aditazz
aditazz
I am using Revit 2016 API to create a family with nest family instance. I want to align inserted family instance with a reference line but getting the error message below.
Autodesk.Revit.Exceptions.ArgumentException was unhandled by user code
HResult=-2146233088
Message=One of the conditions for the inputs was not satisfied. Consult the documentation for requirements for each argument.
Below is the code to call NewAlignment.
	ModelCurve line3 = MakeLine(document, new XYZ(10, 10, 0), new XYZ(5, 15, 0));
	line3.ChangeToReferenceLine();
	Reference refPlaneLeft = GetFamilyInstanceLeftReferencePlane(viewPlan, familyInstance);
	if (refPlaneLeft != null)
		Dimension alignToLine3 = document.FamilyCreate.NewAlignment(viewPlan, line3.GeometryCurve.Reference, refPlaneLeft);
		alignToLine3.IsLocked = true;
private Reference GetFamilyInstanceLeftReferencePlane(
    View view,
    FamilyInstance fi)
    Reference referenceLeft = null;
    Options opt = new Options();
    opt.ComputeReferences = true;
    opt.IncludeNonVisibleObjects = true;
    if (view != null)
        opt.View = view;
    double minX = double.MaxValue;
    GeometryElement ge = fi.get_Geometry(_opt);
    if (ge != null)
        foreach (GeometryObject go in ge)
            if (go is GeometryInstance)
                GeometryInstance gi = go as GeometryInstance;
                foreach (GeometryObject goSymbol in gi.GetSymbolGeometry())
                    if (goSymbol is Line)
                        Line refPlane = goSymbol as Line;
                        if (refPlane.Direction.IsAlmostEqualTo(new XYZ(0, 1, 0)) || refPlane.Direction.IsAlmostEqualTo(new XYZ(0, -1, 0)))
                            if (refPlane.GetEndPoint(0).X < minX)
                                minX = refPlane.GetEndPoint(0).X;
                                referenceLeft = refPlane.Reference;
	return referenceLeft;
Does GetFamilyInstanceLeftReferencePlane() not get the correct Reference of FamilyInstance's ReferencePlane? Or, is there a better way to align FamilyInstance to a reference line?
Aaron.Lu
Hi aditazz, the documentation says:
"These references must be already geometrically aligned (this function will not force them to become aligned)."
that means we have to move those 2 references together before calling NewAlignment,
can you check if that is the reason of the exceptions?
Aaron Lu
Developer Technical Services
Autodesk Developer Network
sonicer
can you send the final code?
thx.
