New to REVIT API which design patterns used the most
WorldDue
WorldDue
Which design patterns and best OOP practices I would use the most when dealing with the REVIT API?
jeremytammik
Before getting started with the API, familiarise yourself with the concept of BIM and the Revit product itself, or nothing will make sense.
Then, work through the Revit API getting started material:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
It is .NET based. General .NET and OOP best practices apply.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
WorldDue
I have worked as an end user on Revit for less than a year actually, not the best as my work was in the scope of academic projects and grad project (Structural division). I think it may be sufficient to start looking into the API itself...
