New plug-in (Duct/Pipe Sizing source code).
Dears,
Need your helps,
Any one here can help me about how I can get the full (Source Code) of a (Duct/Pipe Sizing) Tool in revit, which appeared in "Modify" panel when a pipe or duct is selected?
Thanks.
Charles.Piro
sorry but I don't understand your asked.
You want changed the size of duct (or pipe)with API ?
Or you want add a tool in ribbon "modify" when a duct (or pipe) is selected ?
Smiley Wink
PIRO Charles
Developer
PIRO CIE
Linkedin
MarryTookMyCoffe
you can't get this code, I'm not even sure if it is build on API that we use, it could be build on class that we have no access.
Write what exactly you need, maybe then some one could help you.
do not worry it only gonna take Autodesk 5 years to fix bug
