New idea for addin version management : Open for thoughts
IbrahimNaeem
IbrahimNaeem
Referring to this discussion:
https://forums.autodesk.com/t5/revit-api-forum/addin-version-management/m-p/7261164#M24280
I'd like to share with you more efficient way to keep only one installer for all Revit versions and same dll file as well.
I used dependency Inversion principle and worked nice for this purpose.
here's the code sample:
class PlaneFactory : IPlaneCreator
        Application _app;
        IPlaneCreator creator16;
        IPlaneCreator creator17;
        public PlaneFactory(Application app)
            _app = app;
            creator16 = new PlaneCreator16(_app);
            creator17 = new PlaneCreator17();
        public Plane CreatePlaneByInputs(XYZ Origin, XYZ vx, XYZ vy)
            if (Convert.ToInt32(_app.VersionNumber) > 2016.5)
                return creator17.CreatePlaneByInputs(Origin, vx, vy);
            else
                return creator16.CreatePlaneByInputs(Origin, vx, vy);
        public Plane CreatPlane()
                return creator17.CreatPlane();
            else
                return creator16.CreatPlane();
 I would like to see if you have different thoughts or ideas.
Thanks, Ibrahim Naeem
jeremytammik
Dear Ibrahim Naeem,
Thank you for sharing your nice idea.
Here are my thoughts and suggestions:
  • Great idea, well worth pursuing!
  • Spell check your variables, properties and methods (e.g., `CreatPlane`).
  • Implement a static variable to cache the result of
Cf. some discussion by The Building Coder:
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
