New family instance ends up in 0,0,0 and not given position
ottosson_mathias
ottosson_mathias
I just want to place an air terminal using the doc.Create.NewFamilyInstance. I provide a XYZ location, familySymbol and level and the element gets created. But it ends up in 0,0,0 and not in the provided position.
If I try to manually set the location after the element has been created it ends up in the position but x2(!!).
What am I doing wrong here?
using (Transaction trans = new Transaction(Doc, "Place Air Terminal"))
    trans.Start();
    FamilyInstance airTerminalInstance = Doc.Create.NewFamilyInstance(location, airTerminalSymbol, level, StructuralType.NonStructural);
    LocationPoint locationPoint = airTerminalInstance.Location as LocationPoint;
    // since the location ends up in 0,0,0 I try to change it manually,
    // but this doesn't work either... the locationPoint.Point ends up to be
    // the provided point x2!
    locationPoint.Point = location;
    trans.Commit();
Thanks!
ottosson_mathias
Seems I was a bit too quick. The transaction needed to commit for the location to be updated.
Now it's just the z-value that's not correct.
Edit:
Lol! Seems I've had this issue before! Just forgot about it =P
https://forums.autodesk.com/t5/revit-api-forum/document-create-newfamilyinstance-places-element-with...
jeremy_tammik
LOL indeed. My mind work in a similar way. I forgot everything I ever did. That is the main reason for Tha Building Coder blog.
