.Net Framework4.5.2
.Net Framework4.5.2
MhamedZouheir
.Net Framework4.5.2
MhamedZouheir
Hi every Body
I have couple issues with my model, some views and sheets dispairs when users synchronize with central file.
When I verifierd each user machine I find that there's many version of .netframework (v3.0/v3.5 v4) installed
should we uninstall this version?
Dale.Bartlett
We had some issues with addin errors that were possibly due to .NET 4.5.2. Compiling for 4.0 resolved that problem. However, I can't imagine that the .NET Framework version can affect existing model elements. I would look elsewhere initially. If you are generating Views and Sheets programmatically, you should read this:
// Summary: new sheets created using the API may not show in the printable list View/Sheet Set
// especially if undo-redo is used.
http://thebuildingcoder.typepad.com/blog/2015/06/revit-2016-sp1-and-sheets-missing-from-print-dialog...
Note most particularly the comments.
Regards, Dale
______________
Yes, I'm Satoshi.
MhamedZouheir
not yet,
did not solve the problem.
Dale.Bartlett
Hi, Do you have any add-ins running? You will need to be more specific as to the problem, but it seems to me that this is a Revit issue, not Revit API issue. You may try the other forum. Dale
______________
Yes, I'm Satoshi.
