Nested family read bug
If the family A contains the same name of the sub-family A, B, C; the family D contains the same name of the sub-family D, E, F, then editing the family will be confused.
1) If the name of A is modified, then B will not be able to read the sub-family and save it as another The program will enter an infinite loop and cannot exit;
2) If you do not modify any family name, the program will directly enter an infinite loop, or even crash;
3) Check the same name, skip, and enter an infinite loop or even crash
Full of all kinds of unexplainable internal bizarre problems!!!!!!
NOTE: <Tom.FamilyTree.zip> don't include any my dlls, you could find them by another zip, install it, get them.
I want to upload large zip file, but network is very slow.
Sometime, Revit API don't give you any help, you rename family manually(maybe cannot get child families by API, if parent family and child family are same name) and restart revit.
In a word, nested families cannot have the same name, otherwise everything will be accompanied by uncertainty!!!
Revit Version: 2021
jeremy_tammik
Not only editing is confused; I am confused too.
Yes, for sure.
Afaik, you cannot have different families with the same name loaded into a single project. At least, I would strongly recommend to avoid trying to do that.
Yes. Show the full path of family node to user, user must rename to fix the problem. 🙂
By the way, I closed all exception setting, stack exception don't show. 😅
The follow method is a solution, it could find <FamilyA/FamilyA> problem.
private static bool CheckFamilyName(TreeNode node)
var paths = node.FullPath.Split(new[] { @"\" }, RemoveEmptyEntries);
if (paths.Distinct().Count() == paths.Length)
return false;
// Find A/A; B/B to tell user and should rename manually!
node.FullPath.ShowRevitDialog();
return true;
private void ReadFamilyTree(Document parentDoc, TreeNode parentNode, bool export = false)
var families = parentDoc.OfClass<Family>().OfType<Family>();
foreach (var family in families)
if (family.FamilyCategory is null)
continue;
if (family.FamilyCategory.CategoryType == CategoryType.Annotation)
continue;
if (!family.IsEditable)
continue;
TryAction(() =>
var node = new TreeNode(family.Name);
// It's for 'node.FullPath'
parentNode.Nodes.Add(node);
if (CheckFamilyName(node))
return;
var fdoc = parentDoc.EditFamily(family);
if (export)
var familyPath = Path.Combine(_rootDirPath, node.FullPath) + Res_Type_Rfa;
var familyDirPath = Path.GetDirectoryName(familyPath);
if (!Directory.Exists(familyDirPath))
Directory.CreateDirectory(familyDirPath);
if (File.Exists(familyPath))
File.Delete(familyPath);
fdoc.SaveAs(familyPath);
Application.DoEvents();
_progress.UpdateProgress(++_completedNum, family.Name);
ReadFamilyTree(fdoc, node, export);
fdoc.Close(false);
}, true);
If you want to get full code, please download demo code.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
