Need to list all parameter type names
frankloftus
frankloftus
I want to programmatically add family parameters to a family doc using this method:
FamilyManager.AddParameter(String, ForgeTypeId, ForgeTypeId, Boolean)
To create a parameter, you must input the parameter type. To create a text parameter you would use this:
SpecTypeId.String.Text
But let's say I want to give the user a drop-down menu so they can select which parameter type, similar to the Revit UI:
So, I need to list all parameter type names.
I can use this to get all parameter types:
param_types = SpecUtils.GetAllSpecs()
But how do I get their names?
Everything about ForgeTypeId is very confusing to me.
longt61
You can consider ForgeTypeId is just a fancy Autodesk type wrapping predefined enumeration. A part of it defines unit, while other part defines parameter type (spec type), etc..
As for getting the name of a given SpecTypeId, you might want to take a look at the LabelUtils.GetLabelForSpec() method.
Hope this helps.
frankloftus
Thank you. That is exactly what I needed. I looked through SpecUtils and didn't find any way to get a spec name. I didn't even think to look at another separate util class. I feel that these util classes are not grouped logically with the objects they operate on (not very OOP). Here is the solution I arrived at:
from selection_form_module import selection_form
from Autodesk.Revit.DB import SpecTypeId, SpecUtils, LabelUtils
# Get all param types
param_types_dict = {LabelUtils.GetLabelForSpec(spec) : spec \
					for spec in SpecUtils.GetAllSpecs()}
# Get sorted list of all param_type_names
param_type_names = sorted(param_types_dict.keys())
# Create selection_form
form = selection_form(param_type_names, 'Choose Parameter Type', 'Select')
# Show form
form.ShowDialog()
# Get the selected param_type_name
selected_param_type_name = form.selected
# Get param_type with selected name
selected_param_type = param_types_dict[selected_param_type_name]
# Output param_type
return selected_param_type
