need help finding bounding box for selected section view
rajadeva93
rajadeva93
Here is the code i have using.
even when i select the section view element it's not passing through following if statement. it
if ( element is View)
view = element as View;
i always get the else statement error message
can someone help me
full code below
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System;
namespace RotateElements
    [Transaction(TransactionMode.Manual)]
    public class RotateElementCommand : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIDocument uidoc = commandData.Application.ActiveUIDocument;
            Document doc = uidoc.Document;
            // Get the currently selected view
            View view = null;
            try
                Reference reference = uidoc.Selection.PickObject(ObjectType.Element, "Select a view");
                Element element = doc.GetElement(reference);
                else
                    TaskDialog.Show("Error", "Selected element is not a section view");
            catch (Autodesk.Revit.Exceptions.OperationCanceledException)
                // User canceled selection
                return Result.Cancelled;
            if (view != null)
                // Check if the selected view has a valid crop box
                BoundingBoxXYZ boundingBox = view.CropBox;
                if (boundingBox != null)
                    // Process the bounding box
                    XYZ maxPoint = boundingBox.Max;
                    XYZ minPoint = boundingBox.Min;
                    // Print or use the bounding box coordinates as required
                    TaskDialog.Show("Bounding Box", $"Selected View: {view.Name}\nMax Point: {maxPoint}\nMin Point: {minPoint}");
                else
                    TaskDialog.Show("Bounding Box", "Selected view doesn't have a valid crop box.");
            else
                TaskDialog.Show("Bounding Box", "No view selected or selected element is not a view.");
            return Result.Succeeded;
jeremy_tammik
You could use a selection filter to ensure that the object selected by the user is indeed a View, and nothing but a view:
ctm_mka
A few things, im surprised you are getting the else statement, as doc.GetElement (line 22) wants and ElementId, which you are not feeding it. Try changing "doc.GetElement(reference)" to "doc.GetElement(reference.Id)". Second, "View" is a very broad category, as Jeremy suggested, filtering may help, perhaps by Family, which would return, Detail View, Section View, etc., which i believe you are looking for. Lastly, there are References views to account for, which are also of the View category.
mhannonQ65N2
Document.GetElement has an overload that takes a Reference.
