My first revit plugin help Lesson 1
Nathan.HilsonN67V6
Nathan.HilsonN67V6
Can anybody give quick insight on why this isn't recognizing? Followed all the steps but won't recognize "Execute".
Kevin.Lawson.PE
Hi Nathan, welcome to the Revit API, your life will never be the same.
If you hover over the error and rest the mouse, Intellisense will pop up an error description.
There's also an "Error List" tab on the bottom pane that will give you more info about the error.  Post those and we can be of more help.
My guess is that you are not returning a value. Make sure all code "paths" return Result.Succeeded or Result.Failed.
-Kevin Lawson, PE
www.rippleengineeringsoftware.com
Revit heating and cooling load calculations in one click!
Nathan.HilsonN67V6
Thanks Kevin. I posted the snippets below.
Kevin.Lawson.PE
I was right! "Not all code paths return a value"
The class "Execute" is expecting a "Result" to be returned.  You need to have a "return Result.Succeeded" statement at the end of the Execute code.
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
//do whatver the code does
return Result.Succeeded;
-Kevin Lawson, PE
Nathan.HilsonN67V6
Thanks. You just saved me a ton of time trying to do more research. Everything I found online kept saying I was missing a reference.
Kevin.Lawson.PE
That was my first inclination as well, but you would have had a lot more errors if you were missing a reference.
-Kevin Lawson, PE
