Multiple Collectors
Multiple Collectors
floretti
Multiple Collectors
floretti
Apologies if this duplicates any previous discussions but I've done quite a few searches and couldn't find the answer.
I noticed if I create multiple collectors in the same script they don't work properly and most likely end up empty. I've tried to use Dispose() before creating the second collector to see if it can sort of "reset" the collector but I always get the error below. What is it that I'm missing?
Exception : Autodesk.Revit.Exceptions.InvalidObjectException: The managed object is not valid.
Below is a simple example where I collect all shared parameters in a project first so I can use the GUIDs to collect data from them in families.
collector = FilteredElementCollector(doc)
sharedPars = collector.OfClass(SharedParameterElement)
# Find GUID of desired shared parameters
families = collector.OfClass(FamilyInstance).WhereElementIsViewIndependent()
# Collect data from families based on parameter GUID.
jeremy_tammik
Creating multiple collectors is no problem at all.
Applying several different filters to one single collector does exactly what it should:
Every single filter is applied to the collector results.
If the filters are mutually exclusive, you end up with an empty result.
For a more detailed explanation, please read here:
https://thebuildingcoder.typepad.com/blog/2019/11/design-automation-api-stacks-collectors-and-links....
Also reiterated here:
https://thebuildingcoder.typepad.com/blog/2021/01/sheet-view-xform-coords-img-export-and-title-block...
In your sample below, simply create two separate collectors for shared parameters and family instances.
floretti
Hi Jeremy, first of all I appreciate the reply and support.
I definitely understand what I did wrong now, I can't reuse the same collector variable as the filters just pile up, which obviously causes the collector to be empty, so simple.
It does worry me that after so much research I couldn't find the answer anywhere.
jeremy_tammik
Thank you for your appreciation. Happy to hear that the problem is solved and the solution clear and simple,.
I'll spell it out in the blog again and hope that will be easier to find in case anyone runs into this again in the future.
