Multi session login on Windows 10 Enterprise E3
Using a virtualised multi session login to a cloud hosted machine, is it possible to run multiple instances of Revit using stand alone licenses on a Windows 10 Enterprise E3 OS ?
These OS’ will be sharing the same bare metal CPU and RAM.
jeremytammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
