Moving elements from one level to another
2lenin-off
2lenin-off
Hello! I'm writing a plugin to move elements from one level to another.
private void TransferringElements(object sender, RoutedEventArgs e)
    var newLevel = new FilteredElementCollector(_doc)
        .OfClass(typeof(Level)).FirstOrDefault(x => x.Name == importLevelName) as Level;
    using (Transaction transaction = new Transaction(_doc, "Transaction"))
        transaction.Start();
        foreach (ElementId elementID in ElementsByLevel[exportLevelName])
            Element element = _doc.GetElement(elementID);
            BuiltInParameter[] levelExportParametrs = CommandChangeLevel.GetParametersForMovingItems(element);
// The required parameter is taken from the Dictionary depending on the element type
            var levelNameParameter = element.get_Parameter(levelExportParametrs[0]);
            if (levelNameParameter?.HasValue == true && levelNameParameter.IsReadOnly == false)
                levelNameParameter.Set(newLevel.Id);
        transaction.Commit();
I'm facing some problems:
1. "Object not Cutting anything". How can I fix this situation?
2. How can I get the SuperComponent value of an element?
Accepted solutions (3)
Niko_Davydov
Hi @2lenin-off ,
1. you can use it JoinGeometryUtils Class (revitapidocs.com)
2. not sure what you mean. Maybe that? HostObjectUtils Methods (revitapidocs.com)
Best reagrds,
Nikolai Davydov
rcrdzmmrmnn
1- maybe the element you are trying to copy needs a host and can't find one.
2-Only FamilyInstance have SuperComponent property, cast your element to familyinstance
jeremy_tammik
Check out this post:
https://forums.autodesk.com/t5/revit-api-forum/transferring-elements-from-one-level-to-another-while...
Maybe Julian's Leveler add-in addresses your problem as well.
