Modifying the Document with a Transaction before the built-in Print command
I am working on an add-in that improves the default settings for the built-in print command, based on the active view - the filename, the paper size, etc.
Right now I have it working as I want it to, however, it is hooked up to the ViewActivated event. It parses the activated view's properties and creates a Transaction to modify the PrintSetting and call PrintSetup.Save to apply those changes. I would like to optimize this so that on ViewActivated, the information is only collected, and then applied and saved in a Transaction only just before the actual Print command is executed. The performance hit might be negligible (though I'd like to improve it as a matter of principle), but more annoyingly the Transactions create undoable history steps for every view change, which I would like to prevent.
Hooking my code up to BeforeExecuted for the built-in Print command fails with an error about document modification not being allowed, and I gather from online documentation that the BeforeExecuted Event is indeed read-only.
So, the approaches I'm considering:
- Override the actual Executed event for the built-in Print command - I would only do this if I can somehow easly re-conjure up the regular Print command after doing my own business. Is there a way to do this? Reposting a Command from within the overwritten execution of itself seems like a bad idea.
- Is there a way to Commit a Transaction without an entry in the user transaction history so it doesn't fill up? Seems like really bad practice, but it would be a hacky way to improve the experience.
- Hooking up to something else? I looked into the UIControlledApplication.DialogBoxShowing Event, but it seems like the print options window isn't considered a Dialog Box in that sense. Any other ideas?
Thanks!
