Modifying revit config
Am creating a plugin in c# that is going to be a floating window, I want the window to communicate with a service.  Todo this I need to put some endpoints into the config but I don't want to do this by hand and I was just wondering if you guys have come across needing to include some custom settings in the config and how you got around it.
Chris
Joe.Ye
Hi Chris,
I think you can use the methods and classes in .NET framework to access the standard Revit.exe.config file.
Here is links about accessing XML file.
http://www.c-sharpcorner.com/UploadFile/mahesh/ReadWriteXMLTutMellli2111282005041517AM/ReadWriteXMLT...
http://www.codeproject.com/Articles/11589/Read-Write-Configuration-in-XML-file
Sorry no handy code shows the process.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
I was having the same issue. I wanted to set the ConnectionString property in the Revit.exe.config file programmatically, to be able to us Entity Framework.
I end up using the NET Framework ConfigurationManager Class.
More info:
http://msdn.microsoft.com/en-us/library/system.configuration.configurationmanager.aspx
http://stackoverflow.com/questions/15900612/how-to-read-write-this-app-config-setting
