Modify the position of the dimension
hello,
I am looking for a way to move the dimensions of Figure a as shown in Figure b.
(Using revit API)
jeremytammik
You can probably achieve what you need using the dynamic model update framework DMU:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.31
The DynamicModelUpdate SDK sample demonstrates its use:
Dynamic Model Update used to maintain relative position between elements: Move a section marker to maintain relative position with a window; When execute the AssociativeSectionUpdater Command:
  • Register the SectionUpdater
    • Select a view section element and a window, it will associate the two element.
    • Add a trigger so that the SectionUpdater class will be invoked for any geometry change to the window
  • When the geometry of a window changes
    • Move the section to a new location based the window’s location point and rotate the section and make it vertical to the window’s FacingOrientation.
    • The calculation is on the RejustSectionView function.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
aignatovich
Hi!
The easiest way to achieve it may looks like this (Iron python shell code):
dimension = selection[0] # selected dimension
tx = Transaction(doc, "move dimension")
tx.Start()
ElementTransformUtils.MoveElement(doc, dimension.Id, 0.5*XYZ.BasisY)
tx.Commit()
Of course you need to determine shift direction and distance, I don't know these rules
@jeremytammiksuggested how to do it automatically
